2001 Ford Explorer Clicking Key Off
SEATTLEACE
My 2001 Ford Explorer, 82,000 miles, V-6, is making a clicking sound when the key is out. When I attempt to turn the car over, I get absolutely nothing, including the clicking sound going away. I am guessing this could be a glitch between the battery, solenoid, and starter...OR something having to do with the battery. Does anyone have any ideas, would be greatly appreciated. Thank you.
Oct 29, 2007 at 8:29 AM
BLACKOP555
  • 10,386 POSTS
check ignition switch and starter relay. may not be disengaging power to starter or engine. battery is probably dead also.
Oct 29, 2007 at 12:24 PM
Suggested Repair
Check the ignition switch and starter relay, which may not be cutting power to the starter. Also test the battery, which is likely dead, and charge or replace it as needed.
Conversation Summary
The owner of a 2001 Ford Explorer reports a clicking sound with the key out and no response when trying to start, after which the clicking stops. The expert recommends checking the ignition switch and starter relay for a failure to disengage power, and notes the battery is probably dead.
