2004 Ford Explorer 04 Explorer just rapidly click when star
115,535 MILES • 6 CYL • 4WD • AUTOMATIC
BUCKSHOT86
I got home from school just fine and started the car to go hunting, but it didnt crank. When I fully turned the key, it just clicked really fast. Lights and radio all work. Past few days it has seemed like the car was struggling to start, but it always did until today. Spark plugs maybe? I really have no idea.
Now all I get is the rapid clicks when i start the car.
Oct 29, 2008 at 9:00 AM
DLOBI
  • 125 POSTS
The clicking is coming from your starter motor solenoid. Either the battery is to low to turn over the starter motor or the starter motor has issues. Have you tried jump starting it when it clicks like this? If it starts ok with a jump then the starter is probably ok and the battery is to low on power and you have to find out if it a faulty battery or a charging problem
Oct 29, 2008 at 9:03 AM
BUCKSHOT86
Thanks for a good reply. I think the battery is good, because all the lights and radios were working fine. The gauge shows battery power too. I can still try jumping it. I hope the starter motor is ok, but Ill try jumping. Thanks.
Oct 29, 2008 at 9:23 AM
DLOBI
  • 125 POSTS
The radio, lights, etc take very little battery power compared to the starter motor so they will still work even if the battery is low. The starter has to turn the engine over and requires all the power your "good" battery has.
Oct 29, 2008 at 10:10 AM
BUCKSHOT86
Thanks man,
I jumped the battery and then drove to have it checked. The battery read at 194 CCA and it should be at 300 CCA. Bad Battery. you called it. Ill need a jump in the morning to get to school probably, but Ill have a new battery soon.
Oct 29, 2008 at 4:41 PM
