1955 Ford Explorer Crank Won't Turn
WPOLITE
A few days ago, I removed the transmission to install a new torque converter; of course removing the transaxle was also required. I've replaced the torque converter, and re-installed the transmission and transaxle; I was in the process of installing the torque converter nuts through the starter housing but the problem is the crankshaft won't rotate. I put the drive selector in "Neutral" and the crankshaft still will not rotate. I don't want to snap something by putting too much effort on the socket and ratchet but that's the only way I can locate all of the bolts for the torque converter. Is there something seriously wrong or what seems to be going on? Driveshafts are not attached and just to be sure, I rotated the drive selector on the transmission through all gears but the crankshaft still will not move.........HELP REQUIRED!!!
Dec 8, 2006 at 1:49 AM
INDYUKE
  • 416 POSTS
There is a possibility that the torque converter pilot is binding against the flywheel. The converter studs and converter drain plug must align with the holes in the flywheel and the torque converter must rest squarely against the flywheel. Try reaching your hand up in there and giving the torque converter a push... it shouldn't be tight, there should be a little fore and aft play before bolting it tight to the flywheel. I hope this helps.
Dec 21, 2006 at 6:24 PM
Suggested Repair
Check that the torque converter pilot is not binding on the flywheel. Align the converter studs and drain plug with the flywheel holes so the converter sits squarely, then push the converter in and confirm a little fore-and-aft play before bolting it.
Conversation Summary
After reinstalling a Ford Explorer transmission and transaxle with a new torque converter, the crankshaft would not rotate in neutral or any gear, preventing access to the converter nuts. Driveshafts were not attached. The expert said the converter pilot may be binding against the flywheel and advised aligning the studs and drain plug with the flywheel holes, seating the converter squarely, and confirming slight fore-and-aft play before tightening.
