1996 Ford Explorer changing transmissions
68,000 MILES • 6 CYL • 4WD • AUTOMATIC
JOHNATHEN
I recently purchased this vehicle. The previous owner had the transmission replaced by the junkyard mechanic. It was never fully functional again. It has problems shifting. shifts at very high rpms or feathering the throttle. I inspected the transmission and descovered two things. The identification tag reads 98gt-aaa-?? and at the rear top of the transmission there is a plug socket with nothing pluged in to it. could that be for a speed sensor. I have a few questions. 1. Is this the right transmission for this year of explorer. 2. if not what is the right one. 3. I have a 94 explorer v6 4x4 auto will that trans work in it?
Jan 3, 2009 at 5:37 AM
JGAROFALO
  • 489 POSTS
You could be correct that this may not be the right transmission for the car. I'm not sure exactly when the change was made to electronically controlled shifting. If your transmission has a large black s***** on the side of the case where the shifter linkage connects, then it is electronic. If not, it is mostly mechanical.
If the transmission is electronic, it will use two sensors for speed. One is toward the front of the transmission, and tells the computer the input (turbine) speed. The other is on the transfer case, and tells the computer the output speed. By comparing the two along with engine load, the computer decides which gear to command, and activates shift sensors accordingly. Late shifts would point to a failed or erratic sensor.
If the transmission is NOT electronic, this is a classic symptom of a bad vacuum modulator or a vacuum leak in the line leading to the modulator.
I might also suggest scanning the system for transmission codes.
Jan 3, 2009 at 12:19 PM
JOHNATHEN
Thanks for the info jgarofalo. I think I'm going to have to drop the trans and check it out a little better. I'll try the scanner first.
Jan 4, 2009 at 10:49 AM
