Brake fluid or power steering? what issues and how quickly should it be repaired.[img:f4804d5fe4]http://www.2carpros.com/forum/automotive_pictures/88918_P7271988_1.jpg[/img:f4804d5fe4]
2003 Ford Explorer Power Steering Leak
for your power steering. Keep an eye on the fluid level at the very least. The fluid used is transmission fluid, but check your manual to verify.
https://www.2carpros.com/articles/mitchell1eautorepair-car-repair-manuals
Hard to say how long before you have to do something about it. If it were mine, I might throw a bottle or less of lucas power steering fluid conditioner to see if it helps slow it down. If the fluid goes too low, the pump will get damaged.
Suggested Repair
The leak is at the rack and pinion power steering gear, not the brakes. Monitor the power steering fluid level, verify the correct fluid in the owner's manual (often transmission fluid), and consider a power steering conditioner to slow a small leak. Repair the rack before the fluid gets low enough to damage the pump.
Conversation Summary
The owner of a 2003 Ford Explorer reported a small reddish fluid leak about a foot in from the left front wheel, where the flexible hose starts, near a circular black plug. The right side was dry, and they asked whether it was brake or power steering fluid and how urgent the repair was. The expert identified the leak as coming from the rack and pinion power steering gear, noted that the system typically uses transmission fluid but the manual should be checked, and advised watching the fluid level. A power steering conditioner might slow the leak, but low fluid can damage the pump.
