1998 Ford Explorer Brake fluid resovior emptied but no visi
1998 FORD EXPLORER
121,000 MILES • 6 CYL • 2WD • AUTOMATIC
PHTHOMAS12
My brakes suddenly when to he floor. I checked the brakefluid and it was near empty. I can't find a visible leak anywhere yet a great deal o fluid went somewhere. The brake fluid was checked as full just a few days before this. Is it likely that the fluid leaded into the vacume assist unit via a blown seal in the rear of the master cylinder? If so, could the fliud damage the vacume assist unit?
Thanks!
Aug 6, 2008 at 1:05 PM
SERVICE WRITER
  • 9,123 POSTS
fill it up and pump the pedal, with the engine off.
Carefully look around the inside sidewalls of the rear tires. If this has rear drum brakes, I expect a leaking wheel cylinder to be present.
Aug 6, 2008 at 1:21 PM
