How do you get the rear brake rotors off? I have taken the the pads and caliper off, and removed the center nut that holds the rotor on the splined shaft. Used penatrating oil on the shaft spline, and tapped on the rotor hub. The rotor still will not budge.
Sep 25, 2008 at 5:04 AM
