1995 Ford Explorer Squeak and Delay
DJSUPREME
Whenever I get in and out of the truck, I hear a squeak from underneath. Or if I push it up and down. What could this be? Also sometimes when I put my vehicle in drive, nothing happens for a few seconds...what is this?
Nov 26, 2006 at 11:06 AM
BRUCE HUNT
  • 3,754 POSTS
The squeck I suspect is the age of the vehicle and the rubber mounting bushings etc. under the truck.
The transmission problem, take a look at the tranny fluid level, make sure it is not over full and yet full. If it has been a long time, have the tranny fluid and filter changed.
Nov 27, 2006 at 12:35 AM
Suggested Repair
Inspect the aged rubber mounting bushings under the vehicle for the squeak. Check that the transmission fluid is at the correct level, neither low nor overfull, and change the fluid and filter if service is overdue.
Conversation Summary
A 1995 Ford Explorer squeaks underneath when the owner gets in or out or rocks the vehicle, and sometimes does not move for a few seconds after being shifted into drive. The expert attributes the squeak to aged rubber mounting bushings and recommends checking the transmission fluid level and changing the fluid and filter if it has been a long time.
