1992 Ford Explorer Flexplate Cracking
VETTE63
4x4 Automatic, 4.0 engine, 82,000 miles-Keeps breaking flexplates.Have replaced it 4 times in the last 2 years. What could be causing this???
Jun 11, 2007 at 3:41 AM
INDYUKE
  • 416 POSTS
Where is it cracking?
Here are some things that run through my mind when i hear you keep braking flexplates:
Transmission and engine improperly aligned. Maybe a shim or a washer stuck between the two on one side, or the transmission shifted either too far side to side or up and down.
High transmission line pressure, causing the torque converter to be pushed overly hard against the flexplate.
Improperly torqued flexplate bolts.
I hope this helps. Flexplates do crack, though not often. They tend to fail with age, and mostly crack around the flexplate to crankshaft bolts.
Jun 13, 2007 at 4:20 PM
Suggested Repair
Inspect where the flexplate is cracking. Check engine-to-transmission alignment for a stuck shim or washer or a shifted transmission, excessive transmission line pressure pushing the torque converter against the flexplate, and improper flexplate bolt torque. Cracks often form around the crankshaft bolts.
Conversation Summary
The owner of a 1992 Ford Explorer with a 4.0 automatic reports the flexplate has been replaced four times in two years. The expert asks where it is cracking and suggests checking engine-transmission alignment, high transmission line pressure, and flexplate bolt torque, noting that cracks commonly occur around the crankshaft bolts.
