1994 Ford Explorer Overheat Engine Locked
AYBANKS
I have a 1994 Ford Explorer was driving down the highway and it started to overheat. Stopped to let it cool down. Once it cooled, it started and I was able to go a couple of miles, then it started to lose speed and stopped altogether. Tried to start and it won't start now. All of the lights come on, but all you hear is a clicking sound that I think is coming from the silenoid. Please help me determine what the problem could be. I really need to get home.
Jul 17, 2006 at 1:01 PM
LSUSSEL
  • 252 POSTS
Sounds like you have a bad starter.. did you check that?
Jul 17, 2006 at 1:42 PM
AYBANKS
[quote="lsussel"]Sounds like you have a bad starter.. did you check that?[/quote]
Had that checked out and the starter checked out fine. Any other suggestions?
Jul 17, 2006 at 2:16 PM
JDPHEONIX
  • 5 POSTS
it overheated? maybe theres a problem with your fuel injector and its putting too much gas into the pistons.
Jul 18, 2006 at 4:56 AM
AYBANKS
I will get someone to check it out. Thanks for your help.
Jul 18, 2006 at 6:07 AM
TAURUSWHEEL
  • 718 POSTS
Here's hoping you didn't destroy your motor,, overheating is one of the worst things that can happen to a motor, especially if you continue to drive,, I don't like the part about slowing down and then stopping completely...
Jul 18, 2006 at 10:43 AM
AYBANKS
Looks like that is exactly what I have done. The motor is locked up according to the mechanic, so any tips on where I can get a motor? Bet that is going to cost a pretty penny.... :cry:
Jul 18, 2006 at 12:02 PM
Suggested Repair
The starter tested fine, and a mechanic found the engine locked up after severe overheating. Confirm the seizure and plan on an engine rebuild or replacement.
Conversation Summary
A 1994 Ford Explorer overheated on the highway, lost speed, and then would not restart, producing only a clicking sound. The starter checked out fine. An expert warned that continued driving while overheated can destroy the engine, and the owner later confirmed that a mechanic found the motor locked up.
