1994 Ford Explorer Lunges When Warm
BLONDYGIRL8905
Hi, I bought my 94 Explorer used from a private seller in June 06. Everything was fine until about 2 months ago... When I am in drive, my truck will lunge forward.... about every 3-5 seconds this will happen. The tricky thing is... only when the truck is warm. I asked one of the mechanics in my family, he told me to have to fuel filter replaced... but now that I've done that... it STILL does it! I don't know what to do? Any advice would be very much appreciated!
Nov 17, 2006 at 9:13 AM
ECGRANT
i have a similar problem... did you solve yours?.. ecgrant (loucgrant@aol.com)
Dec 21, 2020 at 3:29 AM
MERLIN2021
  • 17,250 POSTS
If the check engine light has come on get the codes read, Does it idle smooth? You can try a q-tip wet with alcohol to clean the MAF heated wire. Do it with the engine off!
Suggested Repair
If the check engine light is on, have the codes read and check whether the engine idles smoothly. With the engine off, clean the MAF heated wire using a cotton swab dampened with alcohol.
Conversation Summary
The owner of a 1994 Ford Explorer reports that the truck lunges forward every few seconds in Drive, but only after it is warm. Replacing the fuel filter did not stop the problem. The expert recommends reading codes if the check engine light is on, checking idle quality, and cleaning the MAF heated wire with alcohol while the engine is off.
