4x4 Automatic, 4.0 engine, 82,000 miles-Keeps breaking flexplates.Have replaced it 4 times in the last 2 years. What could be causing this???
Jun 11, 2007 at 3:41 AM
Inspect where the flexplate is cracking. Check engine-to-transmission alignment for a stuck shim or washer or a shifted transmission, excessive transmission line pressure pushing the torque converter against the flexplate, and improper flexplate bolt torque. Cracks often form around the crankshaft bolts.
The owner of a 1992 Ford Explorer with a 4.0 automatic reports the flexplate has been replaced four times in two years. The expert asks where it is cracking and suggests checking engine-transmission alignment, high transmission line pressure, and flexplate bolt torque, noting that cracks commonly occur around the crankshaft bolts.
