1992 Ford Explorer fuel in vaccum lines
MARTYEVER
  • 1992 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 150,000 MILES
All tha vaccum lines have fuel in them
Thursday, November 27th, 2008 AT 1:48 PM
ENGINEMAN 73
  • 28 POSTS
DOES TRUCK RUN ROUGH AND/OR DIE? I WOULD CHECK FUEL PRESSURE REGULATOR ON FUEL RAIL. IF REGULATOR DIAPHRAM IS BAD IT WILL LEAK FUEL INTO VACUUM LINE THAT IS ATTACHED.
Saturday, November 29th, 2008 AT 10:35 PM
MARTYEVER
I replaced the fuel pressure regulator and solved the problem thank you
Friday, December 5th, 2008 AT 5:58 PM
