1996 Ford Explorer Seeping fluid lose from thru bellhousing
1996 FORD EXPLORER
162,000 MILES • 6 CYL • 4WD • AUTOMATIC
60VETTE
Transmission started leaking due to flex plate failure. After replacement of flex plate, complete new pump assembly, pump adaptor plate, bellhousing (converter bushing), bellhousing to transmission attaching bolts ( with seals). This unit was in and out a number of times and new gaskets were used each time, with methodical cleaning and assembly of same. Front pump to center support shim was verified for clearance and replaced as well. The last R&R the front bellhousing was changed with another one, problem seepage still occured. Last effort taken, pump adaptor plate was coated with shellac sealer, bellhousing to transmission bolts were sealed with black gasket sealant. This vehicle was operated for some time, fluid leakage continues with a loss of about 200 miles to a quart still coming from thru bellhousing to transmission bolts!
May 15, 2010 at 3:48 PM
  • 110,244 POSTS
Was the torque converter replaced?
May 17, 2010 at 12:50 AM
60VETTE
[quote:3eb1eed466="Jacobandnickolas"]Was the torque converter replaced?[/quote:3eb1eed466] Converter was inspected for wear on seal surface and input shaft was installed to check for , being able to turn one direction. Converter was filled with fluid and checked for leakage. Dye had been installed in trans. to make sure converter wasn't leaking. Converter was not changed.
May 17, 2010 at 5:24 AM
  • 110,244 POSTS
The only thing I can say is the torque converter is bad where it enters the front pump and is causing that seal to leak. There really isn't anything other that would cause that much of a leak.
May 17, 2010 at 11:39 PM
