ABS Light ON
  • 109,896 POSTS
If the sound changes when you turn, chances are you are right, a wheel bearing. Let me know what you find when you have it scanned.
Monday, December 18th, 2017 AT 9:31 PM (Merged)
ROBERT1991TREBOR
My 05 Ford Explorer does the same thing if I go a little too fast around a curve and get some body roll. When it takes the weight off the tire that SOB's "autofour wheel dr" kicks in and KaBlam. My kids spilt somethin sticky on my traction control button and with it pushed down my auto 4wd is disengaged. Temporary fix
KEN L
  • MASTER CERTIFIED MECHANIC
  • 48,416 POSTS
Have you checked the axle bearing hubs in the front it sounds like we have a bearing going out allowing the wheel and ABS sensor to have problems.
Here is a guide to help you see what you are in for when replacing the bearing hub.
https://www.2carpros.com/articles/bearing-hub-replacement
and
https://www.2carpros.com/articles/how-to-replace-an-abs-wheel-speed-sensor
Cheers, Ken
DEBBIE BENJAMIN
  • 2005 FORD EXPLORER
  • 0.6L
  • 6 CYL
  • FWD
  • 110,000 MILES
ABS light on grinding noise when a make a turn no matter if it's left or right
CARADIODOC
  • 33,924 POSTS
Is this grinding noise occurring while the yellow warning light is on? Is it a metal-on-metal grinding or the buzzing sound of the anti-lock system activating? Have you had the diagnostic fault codes read and recorded?
BRANDYGOINS13
  • 152,347 MILES
My abs light on and the 4x4 high blinks on and off
HMAC300
  • 48,601 POSTS
If abs has a problem it won't let 4wd work, have it scanned for codes. Some auto parts can scan for abs.
2CP-ARCHIVES
  • 4,540 POSTS
  • 130,000 MILES
Stuck in 4x4 and abs warning lights saying check anti traction
  • 109,896 POSTS
Have the computer scanned and check the 4wd actuator on the transfer case to make sure it is getting power. If it is, check it for operation.
