Check Adv Trac and ABS Light
2005 FORD EXPLORER
114,000 MILES • 6 CYL • AWD • AUTOMATIC
CSTE6683
The check ADVTRAC warning came on with the ABS light and 4x4 high light flashes sporadically. I no longer have all wheel drive. My rear wheels spun on a wet road. I realize I need a code reader to diagnose. My questions are:
-Is this something a moderately handy home mechanic can do?
-If so what kind of reader do I need? Can I get by with one of the under $100.00 readers? If yes please recommend a reader. Where is the ABS plug in?
-If my guess is right and it is a wheel sensor will the reader tell me which wheel and is this something that can be done at home or are there any special tools or procedures needed?
- Anything else I need to Know?
Thank you,
Dennis
Aug 26, 2010 at 7:17 AM
  • 110,240 POSTS
Dennis,
The two systems work together. Yes, it is most likely a damaged, dirty, disconnected, or a sensor that has wiring damage to it. Check them at each front wheel.
This video will how to you how to check for ABS codes.
https://youtu.be/rTtAnsOlZU4
It sounds like a wheel speed sensor is out the scan will tell you which one. FYI
Aug 26, 2010 at 2:04 PM
KENDRARUSSELL
I had this problem and found the right front ABS wheel speed sensor was out. so I replaced the bearing hub to cost me $210.00. All fixed!
Jul 23, 2018 at 4:46 AM
