2005 Ford Explorer
75,000 MILES • 6 CYL • 4WD • AUTOMATIC
MARTY
The ABS light and the ADVtrac light stay on. Sometimes the 4X4 light flashes. The message says "check advtrac"
Aug 2, 2010 at 2:33 PM
  • 110,246 POSTS
Hi:
The two systems work together. What I need you to check is to make sure the wiring harness to the actuator on the transfer case is clean tight and not damaged. If it is in good condition, the only thing you can do is have the computer scanned to identify where the problem is coming from.
Let me know what you find.
Aug 2, 2010 at 4:15 PM
