2003 Ford Explorer ABS Light On
REDNEKPRINCES24
I have a 2003 Ford Explorer 104,000 miles. My ABS light came on and then went off then came on then went off. The light did this about 3 or 4 times. Now it just stays on. When I brake it vibrates alot. We changed the front brake pads and checked the back they are great.... Im assumeing that it is my ABS sensor I was wondering how can I tell if its the wheel sensors or the ABS sensor itself? And is there any way to tell wich sensor is bad other than a computer wich I dont have :D Thanks for your Help!!! :D
Oct 4, 2007 at 6:03 AM
MERLIN2021
  • 17,250 POSTS
Seeing as how the codes for anti-locks are in the 1100-1200's you really need to get the codes read! You can spend a forune on parts unless you know what to test, My own ABS light came on, and I had to get the codes read, they showed RR sensor was bad, I tested the wires with an ohm meter and found a short at the passenger side compartment, where the wires go thru the firewall. If you have an ohm meter, test the sensors by using OHM's at lowest setting, meter should read between 800-1400 ohms.
Oct 4, 2007 at 8:15 AM
Suggested Repair
Have the ABS codes read before replacing parts. If using an ohmmeter, test the wheel speed sensors on the lowest ohms setting; they should read about 800-1400 ohms. Also inspect the sensor wiring for shorts.
Conversation Summary
The owner of a 2003 Ford Explorer with about 104,000 miles reported an ABS light that flickered several times and then stayed on, plus strong vibration when braking. Front pads were replaced and rear pads looked fine. The owner suspected an ABS or wheel sensor and asked how to identify a bad sensor without a scan tool. The expert said ABS codes should be read first to avoid replacing parts unnecessarily, and that sensors can be checked with an ohmmeter for roughly 800-1400 ohms, noting a similar case caused by a wiring short.
