2000 Ford Explorer Oil Pressure Sending Unit
MDIAZ
  • 2000 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 194,000 MILES
Do I have to drop the transmission to change the oil pump on a 2000 Ford Explorer V-6? And also, where would the oil pressure sending unit llocated?
Sunday, September 20th, 2009 AT 1:24 PM
  • 110,055 POSTS
You shouldn't have to remove the trans to get the pan off. As far as the sending unit, it should be near the oil filter.
Sunday, September 20th, 2009 AT 1:28 PM
The oil pressure switch is on the engine next to the power steering pump.
https://www.2carpros.com/forum/automotive_pictures/12900_oilk_pr_essure_switch_1.jpg
Sunday, September 20th, 2009 AT 1:32 PM
