2000 Ford Explorer Shakes Over 65 MPH
CHICHI13
I replaced my front hubs , bearings and brake pads today .(l/r front) Now if I go over 65mph, it shimmies and shakes real bad. Can you help?
Sep 2, 2007 at 7:26 PM
MERLIN2021
  • 17,250 POSTS
Double check your bearing adjustment!
Sep 3, 2007 at 12:24 AM
CHICHI13
how do I chek the bearing adjustment, these were ready to install. how do I send donation?
Sep 3, 2007 at 5:35 AM
MERLIN2021
  • 17,250 POSTS
What did you touque the nut to? should be 157-213ft lbs! Use a new nut and washer!
https://images.2carpros.com/forum/automotive_pictures/62217_SYNusenfileGF1128A_gifgenref_1.gif
Sep 3, 2007 at 9:16 AM
Suggested Repair
Recheck the front hub bearing adjustment. Torque the nut to 157-213 ft-lbs and install a new nut and washer.
Conversation Summary
After replacing both front hubs, bearings, and brake pads, a 2000 Ford Explorer 4WD with the 4.0 shakes badly above 65 mph. The expert advised rechecking the bearing adjustment, torquing the nut to 157-213 ft-lbs, and using a new nut and washer.
