1992 Ford Explorer Vibration at 55-60 MPH Fix
SEANWV
1992 Ford Explorer XLT, 4.0 V6 Engine, 4 wheel drive, 125,000 miles.
Vehicle vibrates between 55 and 60 MPH when the gas pedal is pressed. The vibration stops when the pedal is released, or the speed is increased to 65 MPH.
Repairs done so far:
Tires rotated
Rear bearings replaced
U-Joints replaced
Front end aligned
Drums and rotors replaced on all four wheels
Any help will be appreciated.
Jan 17, 2007 at 5:01 AM
HEAVYDUTY
  • 60 POSTS
plugs and wires for a possible misfire
Jan 17, 2007 at 1:17 PM
CARUNDELL
  • 602 POSTS
[quote:7982c990dd="SeanWV"]1992 Ford Explorer XLT, 4.0 V6 Engine, 4 wheel drive, 125,000 miles.
Tires rotated
U-Joints replaced
Front end aligned
Any help will be appreciated.[/quote:7982c990dd]
Hey sean
2 items I did not see .....tire balance checked? and which u joints were changed? Let us know!
Chris
Jan 17, 2007 at 10:25 PM
SEANWV
Plugs and wires were replaced 2,000 miles ago on the regular tune-up. The vibration comes from the rear of the car, not the front.
The tires are brand new, replaced 8,000 miles ago, when I bought the car. I did rotate the tires when the vibration started, no change.
And both rear drive shaft U-joints were replaced.
Jan 18, 2007 at 7:11 AM
SEANWV
Just an update for anyone with a similar problem:
I rebuilt the rear, and the problem seems to be fixed. I've driven it 75 miles over the past two days, and there is no sign of any vibration yet.
Jan 24, 2007 at 3:26 PM
CARUNDELL
  • 602 POSTS
[quote:cc7c3c6e34="SeanWV"]Just an update for anyone with a similar problem:
I rebuilt the rear, and the problem seems to be fixed. I've driven it 75 miles over the past two days, and there is no sign of any vibration yet.[/quote:cc7c3c6e34]
Awesome!
Chris
Jan 24, 2007 at 6:55 PM
Suggested Repair
After tires, rear bearings, both rear driveshaft U-joints, alignment, and brakes were already addressed, rebuilding the rear eliminated the load-related vibration. Confirm tire balance and inspect the rear driveline and axle assembly if the symptom returns.
Conversation Summary
A 1992 Ford Explorer vibrated between 55 and 60 mph only while accelerating; the vibration stopped when the throttle was released or speed reached about 65 mph. Tires, rear bearings, both rear driveshaft U-joints, alignment, drums, and rotors had already been serviced, and plugs and wires were recently replaced. The owner said the vibration came from the rear. After rebuilding the rear, about 75 miles of driving showed no vibration.
