1992 Ford Explorer Front Wobble
SHOOONE
92 Ford explorer 4 wheel drive, 4.0 V6 engine.
About a year ago i put a 3 inch body lift on the explorer so I could fit some super swampers on it. I drove great after the mods. No shimmy no shake. About a month ago the front end started shaking, you could feel it in the steering wheel. So i went and had the tires balanced. that helped a little but not a lot. Next i checked the wheel bearings in the front. They were bad so I replaced those, the rotors, brakes and i put a new set of shocks on. The truck drove great. Now here is the problem it only drove good for about 200 miles and then the shakiness slowly started coming back. today i noticed that when i reverse the truck and then go ahead it makes the front end wobble from right to left at about 35 mph. when i say wobble i mean i couldn't hardly hold on to the steering wheel. please help me i am running out of ideas.
Mar 26, 2007 at 5:58 AM
2CARPRO JACK
  • 11,533 POSTS
Drag link and tie rod ends.Also check the Radius Arm bushings
Mar 26, 2007 at 8:20 AM
MERLIN2021
  • 17,250 POSTS
Also the bigger the tire the grater the wear. On ALL parts! Brakes included!
Mar 26, 2007 at 9:42 AM
Suggested Repair
Inspect and replace worn drag link and tie rod ends, and check the radius arm bushings. Larger tires increase wear on steering, suspension, and brake parts.
Conversation Summary
The owner of a 1992 Ford Explorer 4x4 with a 3-inch body lift and large tires reports front-end shake that returned after tire balancing, wheel bearings, rotors, brakes, and shocks. The wobble is severe around 35 mph after reversing and then driving forward. Experts recommend checking the drag link, tie rod ends, and radius arm bushings, noting that larger tires increase wear on all parts.
