HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Explorer
Drivetrain
Transfer Case
1999 Ford Explorer four wheel drive
DAVID LE
MEMBER
1999 FORD EXPLORER
6 CYL
4WD
AUTOMATIC
14,800 MILES
What procedure do I use to turn my 4 wheel drive on and off?
Wednesday, November 12th, 2008 AT 6:49 PM
DAVID LE
MEMBER
SPONSORED LINKS
Wednesday, November 12th, 2008 AT 6:51 PM
Please
login
or
register
to post a reply.
Related Transfer Case Content
1999 Ford Explorer 4wd
1999 Ford Explorer 6 Cyl Automatic 155 Miles Can You Tell Me If The Explorer Sport Has 4wd
Asked by
help4me2
1999
FORD EXPLORER
GUIDE
Transfer Case Replacement
An automotive transfer case is designed to distribute engine horsepower to the front and rear wheels equally by using two driveshafts and is usually bolted to the rear of...
1999 Ford Explorer
Electrical Problem 1999 Ford Explorer 4 Cyl Four Wheel Drive 171.00 Miles Por Favor, Necesito Ayuda, Se Me Apaga El Carro De Momento Y...
Asked by
reyesrey
1 ANSWER
1999
FORD EXPLORER
2003 Ford Explorer 4 Wheel Drive
4x4 Light Blinks Ten Times Every Two Minutes And 4 Wheel Drive Only Works Part Time
Asked by
rs1962
1 ANSWER
2003
FORD EXPLORER
2002 Ford Explorer 4 Wheel Drive
How Do I Check To See If The Automatic 4 Wheel Drive Is On? Also Should It Be Engaged Even In Dry Weather?
Asked by
DAB628
1 ANSWER
2002
FORD EXPLORER
1993 Ford Explorer 4 Wheel Drive
I Just Purchased A Ford Explorer And Went To Put It In 4 Wheel And None Of The Lights Come On And Its Not In 4 Wheel
Asked by
stripers01
1 ANSWER
1993
FORD EXPLORER
VIEW MORE
SPONSORED LINKS
Driveshaft Removal
Wheel Bearings and Seal Replacement
CV Axle Bearing Press
Online car repair manuals
