4WD was an option on them. Can you tell me if there is a differential in the front or take a picture of the underside of the front end so I can see it? Also, is there a 4wd switch on the interior?
SPONSORED LINKS
Sunday, September 19th, 2010 AT 1:20 PM
HELP4ME2
MEMBER
I saw a awd switch on the dash but haven't seen a lever and also the check engine and abs light r on could you tell me what this could posibly mean
Sunday, September 19th, 2010 AT 3:53 PM
MECHANIC
You have the electric shift 4wd, so I will say you have it.
As far as the lights, have you had the computer scanned for trouble codes?
