1993 Ford Explorer 4 wheel drive
STRIPERS01
  • 1993 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 181,000 MILES
I just purchased a ford explorer and went to put it in 4 wheel and none of the lights come on and its not in 4 wheel
Saturday, February 21st, 2009 AT 4:08 PM
  • 109,885 POSTS
Hi:
what I need you to do is check to see if there is power to the 4wd actuator on the transfer case. Have a helper run the controls in the truck while you check. If there is power, remove the actuator and have it checked. Chances are it's bad.
Let me know what you find.
Saturday, February 21st, 2009 AT 7:37 PM
