Checked fuses and they are working fine, but turn signals wont work. What do I check next and where is it locoated?
Monday, March 22nd, 2010 AT 5:21 PM
BLUELIGHTNIN6
MECHANIC
Do hazard flashers work? If not, check for faulty turn signal/hazard flasher relay located in steering column. If hazards do work then check signal switch.
SPONSORED LINKS
Monday, March 22nd, 2010 AT 5:26 PM
NANS
MEMBER
1 POST
Thank's you were helpful and speedy getting back to me but I don't know where to look for the signal switch
Monday, March 22nd, 2010 AT 5:38 PM
BLUELIGHTNIN6
MECHANIC
The signal switch is the part you use to turn on and off the turn signals.
