1998 Ford Explorer Turn Signal
1998 FORD EXPLORER
11,200 MILES • 6 CYL • 4WD • AUTOMATIC
POLOBOY3
My turn signal is not working and I am trying to locate in my manual which fuse it is and the manual does not state which fuse to replace. Can you please let me know?
Thanks
Mar 29, 2010 at 5:59 AM
BLUELIGHTNIN6
  • 16,542 POSTS
check fuse #10 (7.5 amp) in the fuse panel located on driver's side end of instrument panel. if fuse is good then check signal flasher relay located in steering column.
Mar 29, 2010 at 8:52 AM
POLOBOY3
Thank You very much for the information
Mar 30, 2010 at 7:10 AM
