1998 Ford Explorer No Crank
RSALEXANDER
I have a 1998 ford explorer with 155000 miles. It is an EB edition. I replaced a relay under the hood for the blower (which still will not blow in the front onl in the rear) and now I have power too the car but it will not turn over. All the relays are good. You can jump the relay with your had(cover off) and it will turn over but when you put the cap back on it will not turn over. Can anyone help with this. Is it a grounding problem or what do you think?????????????? Help please
May 21, 2007 at 6:11 AM
RUDPRO
  • 224 POSTS
Which relay are you pushing in by hand?
May 21, 2007 at 8:30 AM
RSALEXANDER
I have checked fuse #5 and relay #6 under the hood
May 21, 2007 at 12:44 PM
RUDPRO
  • 224 POSTS
Which relay are you pushing in by hand. Not just the number but it should be marked what it is for. The relay might be bad if it won't hold by itself or it might not be getting a signal because of something else like the camshaft or crankshaft position sensor.
May 21, 2007 at 3:20 PM
Suggested Repair
Identify the relay being pressed by its label, not only its number. Replace it if it will not stay engaged on its own. If the relay is good, check why it is not receiving a control signal, including the camshaft or crankshaft position sensor.
Conversation Summary
The owner of a 1998 Ford Explorer says the vehicle has power but will not crank after a blower relay was replaced. Pressing the relay by hand makes it crank, but it will not crank with the cover installed. Fuse 5 and relay 6 were checked. The expert says the relay may be bad if it will not hold, or it may not be receiving a signal from the camshaft or crankshaft position sensor.
