1995 Ford Explorer Intermittent No Start
2CARPRO JACK
  • 11,533 POSTS
I have a 1995 Ford Explorer XLT, mileage 117000. In the last month it has not started twice. The first time I left my job in my car, drove to a gas station to fill up, filled up the tank. When trying to start the car, the engine would not fire, but the starter and battery were working fine. Then eventually it miraculously started.
1 month later the same thing happened. I was getting in my car at night to go to work, tried to start, but the engine wouldn't fire.
Had my car towed to the dealership, and my car started just fine for them. They had it for 4 days, did their diagnostics, and never found anything. I've seen some mention of the fuel pump in these threads, but wouldn't the dealership have looked at that? I've had to buy a new car because the 1995 Explorer is now unreliable, but I'd like to get it fixed to sell.
Apr 5, 2007 at 8:06 AM
2CP-ARCHIVES
  • 4,540 POSTS
If nothing fails tests or is malfunctioning, what do you replace? Next time it fails to start check for spark and fuel to see what direction to go in and get back to us
Apr 5, 2007 at 1:40 AM
BHUGG
  • 157 POSTS
I had fairly similar troubles with my explorer. I would just shut off while running.
The problem was the electronic engine controls relay. It is a box relay under the hood in the power distribution box. You can switch it out with the blower motor relay and see if the problem goes away.
Let the forum know what happens.
Apr 5, 2007 at 5:31 PM
Suggested Repair
On the next no-start, check for spark and fuel. Also test the electronic engine controls relay in the underhood power distribution box by swapping it with the blower motor relay.
Conversation Summary
The owner of a 1995 Ford Explorer reports an intermittent no-start: the starter and battery work, but the engine will not fire. A dealer could not reproduce the fault. Advice was to check spark and fuel on the next failure and to test the electronic engine controls relay by swapping it with the blower motor relay.
