1995 Ford Escort No Start Timing Belt
JAMESCALVERT
My 95 Ford Esscort (low miles) shut off on the road and wont start. Engien, wont start, turns over with visable spark form plug wire when pulled off and checked next to valve cover. Checked fuel pressure valve at engein in-take area with screwdriver(to open valve) while starting, shoots out 8 inches when opened. And fuel reset button in back trunk was checked. Turns over but no start up. What can I check next?
Oct 28, 2006 at 12:25 PM
NOS
  • 320 POSTS
ok lets try this first where the air goes into the intake pull that hose off open the throttle and flood it down inside it with carb cleaner. (NOT STARTING FLUID) unleass you feel like getting burned real bad.Please us carb cleaner onec this is done put the hose back and crank motor and see if it hits if id does reply back and we go from there.
it has been awhile on an escort but does it have a distributor if not i have an idea what it is but i need to know the rest of this stuff first.(NOS) 8)
Oct 28, 2006 at 12:40 PM
JAMESCALVERT
Looks like the distributer shaft is not their so just a place to plug the spark plug wires. I will have to wait till tomorow to do carb clean method. I looked at timing belt. It does not turn while engine start is attempted. Also some ware on out side of belt and alt, water pump, AC, etc belt is glazed and cracking. I will replace tomorow also. Thanks for the help. Will you be around tomorow?
Oct 28, 2006 at 1:57 PM
NOS
  • 320 POSTS
yes i'am no most of the time to check message and progress of items i have answered(NOS)
Oct 29, 2006 at 12:22 PM
NOS
  • 320 POSTS
if the belt is not turning that may very well be your problem. some motors it won't hurt crank with a busted belt but on other it could bend the valves.that is one one of the reason i wanted to know what motor it was.also even know it sprays a lot of fuel out it don't really me there is enough pressure to make it start(NOS) 8)
Oct 29, 2006 at 12:27 PM
Suggested Repair
Because the timing belt does not turn while cranking, inspect it for failure and replace it if broken; be aware some engines can bend valves. Also replace the glazed, cracking accessory belt. A carb-cleaner spray into the intake can show whether the engine will fire, and the fuel spray should be confirmed as adequate pressure rather than assumed sufficient.
Conversation Summary
A 1995 Ford Escort shut off while driving and cranks but will not start. The owner reports visible spark, fuel spraying from the intake pressure valve, and a checked fuel reset switch. The timing belt does not turn during cranking, and the accessory belt is glazed and cracking. The expert suggested a carb-cleaner intake test, noted that fuel spray does not prove adequate pressure, and said a non-turning timing belt may be the cause, with possible valve damage on some engines.
