Engine shuts off while driving
JIMINOHIO2010
  • 9 POSTS
Also if its is the crankshaft sensor why would it start working again after about a hour or two sitting
Friday, October 9th, 2020 AT 11:40 AM (Merged)
  • 109,896 POSTS
They cool off and will work again. However, the fuel pump shouldn't be running consistantly. When you first turn the key, you should hear it for about a second or two.
JIMINOHIO2010
  • 9 POSTS
Where is the crankshaft position sensor located on a 1995 ford exployer 4.0 4wd
  • 109,896 POSTS
It is near the front harmonic balancer on the end of the crank shaft.
https://www.2carpros.com/forum/automotive_pictures/249084_5_56.jpg
JIMINOHIO2010
  • 9 POSTS
Ok when the engine stalled I took normal water and cooled the crankshaft sensor for 5 minutes. I did this six times to make sure it did it every time the same. All 6 times the engine restarted after 5 minutes. Since the water was sprayed there and some may have hit other area would there be anything else that you can think of when I cooled that area down that would have the same affect
  • 109,896 POSTS
There isn't anything other that is there.
