1993 Ford Explorer fan clutch
LEEBAX
  • 1993 FORD EXPLORER
  • 6 CYL
  • MANUAL
  • 125,000 MILES
Trying to remove water pump fan clutch picture does not match one on website have serptine belt is nut on front of pulley the one to be removed and right hand thread?
Friday, September 24th, 2010 AT 8:57 PM
  • 109,885 POSTS
Here is a picture of the fan clutch. The 36mm (if I remember correctly) bolt is the one that attaches to the pump. It is a standard thread. It faces the water pump.
https://www.2carpros.com/forum/automotive_pictures/249084_5_73.jpg
Let me know if this helps.
Saturday, September 25th, 2010 AT 12:49 AM
  • 109,885 POSTS
First, thanks for the positive feedback. It's appreciated.
They make a special tool for removal. Many nationally recognized parts stores will lend or rent them. If you want the truth, I find the rental tools cheap and not that great. What I do is take a large cresent wrench or open end, put it on the nut, and smack it with a dead blow hammar. It usually takes a good 3 or 4 hits, but it breaks them loose. Make sure to leave the serp belt on to help hold the pully still and I usually wedge something behind the pulley to further hold it in place.
Let me know if it helps.
Saturday, September 25th, 2010 AT 11:31 PM
