HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Explorer
Drivetrain
Transfer Case
SPONSORED LINKS
1993 Ford Explorer Crank but cuts off when put into gear
SASHASALINAS
MEMBER
1993 FORD EXPLORER
Engine Mechanical problem
1993 Ford Explorer 4 cyl Four Wheel Drive Automatic
I can crank the truck up and it will run, however when I go to put it into gear it will cut off on me. What can cause this?
Saturday, June 20th, 2009 AT 7:48 PM
JGAROFALO
MECHANIC
Possible cause is the torque converter is locked up. Does this happen in ANY range except PARK or NEUTRAL?
SPONSORED LINKS
Wednesday, June 24th, 2009 AT 12:42 PM
Please
login
or
register
to post a reply.
Related Transfer Case Content
1993 Ford Explorer 4 Wheel Drive
I Just Purchased A Ford Explorer And Went To Put It In 4 Wheel And None Of The Lights Come On And Its Not In 4 Wheel
Asked by
stripers01
1 ANSWER
1993
FORD EXPLORER
GUIDE
Transfer Case Replacement
An automotive transfer case is designed to distribute engine horsepower to the front and rear wheels equally by using two driveshafts and is usually bolted to the rear of...
93 Ford 4x4
I Need To Know How The 4 Wheel Drive Works On The 93 Ford Explorer? Is It Electrical Or Is It Vacuum? I Need A Diaphagm!
Asked by
sekurtz
1 ANSWER
1993
FORD EXPLORER
1993 Ford Explorer
Computer Problem 1993 Ford Explorer 6 Cyl Four Wheel Drive Automatic Na Miles Where Is The Computer At On A 1993 Ford Explorer
Asked by
jameswhittington
1 ANSWER
1993
FORD EXPLORER
2003 Ford Explorer 4 Wheel Drive
4x4 Light Blinks Ten Times Every Two Minutes And 4 Wheel Drive Only Works Part Time
Asked by
rs1962
1 ANSWER
2003
FORD EXPLORER
2002 Ford Explorer 4 Wheel Drive
How Do I Check To See If The Automatic 4 Wheel Drive Is On? Also Should It Be Engaged Even In Dry Weather?
Asked by
DAB628
1 ANSWER
2002
FORD EXPLORER
VIEW MORE
SPONSORED LINKS
Driveshaft Removal
Transmission Filter and Fluid Replacement
Wheel Bearing Hub Replacement
Online car repair manuals
