2003 Ford Expedition No Oil Pressure
TVILL28
My 2003 Ford Expedition 4.6L has a blown head gasket. The mechanic says ther is no oil pressure and suggest engine change. Are there any alternatives to this? The vehicle starts and runs.
Feb 26, 2007 at 11:24 PM
MATHIASO
  • 1,209 POSTS
If there is no oil pressure at all,check the oil pump drive,it may be broken or the pickup screen is plugged.check the oil level for leak and check if the gallery plugs are leaking.Also check if there is a hole in the pickup tube.
Feb 27, 2007 at 12:50 AM
Suggested Repair
Before replacing the engine, check the oil pump drive, pickup screen, oil level and leaks, gallery plugs, and pickup tube for a hole.
Conversation Summary
The owner of a 2003 Ford Expedition 4.6L reports a blown head gasket and no oil pressure. The mechanic recommends an engine replacement, although the vehicle still starts and runs. The expert advises checking the oil pump drive, pickup screen, oil level and leaks, gallery plugs, and pickup tube.
