1999 Ford Expedition Stalls in Gear
IRISHREBEL
I have a 1999 Ford Expedition XLT 5.4L engine with 131,000 miles. The engine starts fine but then when placed in gear the engine stalls out. The engine light is on and remains on after the engine is started. Sometimes the vehicle will function for a short distance but stalls once the vehicle has come to a complete stop. It idles fine in "Park" and in Nuetral. It only stalls out when it is in reverse or in drive. Is this the fuel pump or O2 sensor or possibly something more.
Jan 3, 2007 at 1:03 PM
SERVICE WRITER
  • 9,123 POSTS
Need to find what codes are in the computer to begin to narrow it down.
Fords seem to have egr and dpfe troubles, but wouldn't jump to that without knowing the codes.
Jan 3, 2007 at 1:09 PM
2CARPRO JACK
  • 11,533 POSTS
Definitly needs to be scanned for codes. IAC motor, vacuum leak would be places to start.Inspect where the pcv line connects to the rear of the intake, Ford had issues with the rubber going soft and creating a vacuum leak. Good luck
Jan 3, 2007 at 11:28 PM
Suggested Repair
Scan for trouble codes before replacing parts. Check the IAC motor and vacuum leaks, especially the PCV line at the rear of the intake where the rubber can soften. Do not assume EGR, DPFE, fuel pump, or oxygen sensor failure until codes are known.
Conversation Summary
A 1999 Ford Expedition 5.4L starts and idles in park and neutral but stalls in drive or reverse, with the check engine light on. Experts recommend scanning for codes first, then checking the IAC motor and vacuum leaks, including the PCV hose at the rear of the intake. Common Ford EGR and DPFE issues should not be assumed without codes.
