2002 Ford Expedition Sluggish Power
2002 ALL OTHER MAKES ALL OTHER MODELS
SPAVEK
Hi. I drive a 2002 Expedition. For the past couple of weeks I have only driven my truck twice and both times it ran perfect and was running perfect before then. But a couple days ago I decided to clean the engine area with some degreaser and hosed it down with some water. I waited a while for the engine to dry before I drove. But now I am having problems. When I start to drive, the truck feels as though it is getting somewhat sluggish power and vibrates a little. But once I get up to about 70ish it runs fine. My friend thought that it may be misfiring, but why would it do that all of a sudden? I thought that maybe something got wet thats not supposed to be and hasnt dried yet. Any ideas?
Apr 1, 2006 at 5:56 PM
LOSONE
  • 1,616 POSTS
I hope the engine was cold when you washed it. The heat will condense water in a lot of places. The best start is to remove a plug wire one at a time and spray it with DW-40 on each end. Remove the connectors to the coil packs and do the same. Wait about 10 minutes and see how the engine performs.
Many people don't know but the WD stands for water displacement. It is flamable that is the reason for the wait.
OPen the hood and start the engine in complete dark and see if you see any odd sparking. Have you set a check engine light??
Apr 2, 2006 at 6:58 AM
SPAVEK
yeah the engine was cold when i cleaned it. i knew better than to do that when it was hot.
i thought that it may have been something to do with the spark plugs. and yes i have seen the check engine light
Apr 2, 2006 at 2:38 PM
LOSONE
  • 1,616 POSTS
Have the codes taken (auto zone does it free) and you will probably see a missfire code. It will tell you the cyl and then you can correct that cyl misfire
Apr 3, 2006 at 12:10 AM
Suggested Repair
Have the check engine codes read, which AutoZone can do free, to identify the likely misfiring cylinder. Spray WD-40 on each spark plug wire end and coil pack connector to displace moisture, wait about 10 minutes, then retest. Also start the engine in the dark and look for arcing.
Conversation Summary
The owner of a 2002 Expedition reports sluggish power and slight vibration after cleaning the cold engine bay with degreaser and water, although it runs fine around 70 mph. The check engine light is on. The expert attributes this to moisture in the ignition system and recommends drying the plug wires and coil connectors with WD-40, checking for sparking in the dark, and reading codes to identify the misfiring cylinder.
