Ignition Coils
MONKEBZNSS2001
  • FORD EXPEDITION
My 2000 Eddie Bauer Expedition with a 5.4liter V-8 has a coil going bad causing surges when under load. The engine light has not come on, and the bad coil cannot be diagnosed with a computer. How can I determine which coil it is?
Thanks for the help!
Tuesday, February 20th, 2007 AT 11:24 AM
CHEVY22
  • 1,375 POSTS
If it has a noticeable miss that you can feel or hear, you can use insulated pliers, and pull one wire at a time and see which one makes no difference, a scan good tool would reveal this problem, you would be able to see the cylinders firing and fords wds can do a stress test on the coils,
caution when pulling plug wires, dont touch metal, and use the right pliers, coil spark may not seem like much but it does sting pretty good
Tuesday, February 20th, 2007 AT 12:26 PM
NOS
  • 320 POSTS
If i'am not misstaken each cyclinder has a coil over each plug. A lot of times moisture will collect inside the holes where the plug boots are and will cause crossfireing in the hole only way I know to check them is to pull each one and check for moisture if engine has been washed at anytime that is a sure fired way to get moisture. NOS 8)
Tuesday, February 20th, 2007 AT 10:05 PM
