1998 Ford Expedition coil pack
KIM4148
  • 1998 FORD EXPEDITION
  • V8
  • 122,500 MILES
How to change a coil pack. I got a reading of a number 8 cylinder misfire and I am trying to change it
Monday, November 10th, 2008 AT 5:07 PM
  • 109,885 POSTS
Hi:
It's really to replace, but #8 is hard to get to. All you need to do is remove the one (I think 7mm or 8mm bolt holding the coil pack in. Once the bolt is out, disconnect the wiring plug to the pack and pull it out. It looks like it will hit the fuel rail, but it will come out. To replace it, just do the opposite.
NOTE: Over the years, I have found it a good idea to replace the plug too. Also, many times the coil pack isn't bad and all that needs to be replaced is the rubber boot that goes from the coil pack to the plug. Check for gray spots where there may have been an arc of power to the engine and not to the plug. If you find that, try replacing the boot rather than a 60 dollar coil.
Let me know if you have any questions. I'll be glad to help.
Positive feedback is appreciated.
Tuesday, November 11th, 2008 AT 11:49 AM
