1998 Ford Expedition OBD codes 1131 and 1151
ENG961
  • 1998 FORD EXPEDITION
  • V8
  • 143,000 MILES
Installed #2 cyl. Coil and started engine and got 1131 and 1151 codes. Whats the fix
Friday, August 20th, 2010 AT 1:30 PM
MERLIN2021
  • 17,250 POSTS
It can mean you need new O2 sensors, both front sensors are stuck on lean, and not switching as they should, or you have a major vacuum leak. Air duct back in place? Also possible the fuel pump is on the way out.
https://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
Go here and checkout our video.
Friday, August 20th, 2010 AT 1:57 PM
