The #4 coil burns out in a week?
SFCBIGFRANK
  • 1998 FORD EXPEDITION
  • V8
  • 4WD
  • 180,000 MILES
The #4 coil burns out in a week change it and 1 week later it goes out. Help!
Thursday, July 22nd, 2010 AT 1:00 PM
SQM
  • 6,383 POSTS
In order for a coil to keep going bad in such a short period of time, there has to be an underlying cause. That can be high secondary resistance due to worn spark plug or excessive gap in the spark plug.
It can also go bad if the engine runs lean for extended periods of time.
However the most common cause is bad plug.
Check and verify that the plug on that cylinder is in good shape and gap is correct.
Visually check for any build up on the spark plug.
The gap should be 1.3 to 1.4 mm (0.051 - 0.055 in).
https://youtu.be/c9_NVXiwvYg
Monday, August 16th, 2021 AT 10:41 PM
