2003 Ford Excursion Turn Signals Out
PIERSALLG
2003 Excursion Limited, V-10, 4X4. Turn signals don't work. 4-way flashers do. All lights good. Fuse good. Suspect flasher module if such there be. Can't find it. Where should I look?
Thanx.
Feb 10, 2007 at 9:29 AM
SERVICE WRITER
  • 9,123 POSTS
In auxillary relay box # 1, which is located behind the glove box. Makes you want to kiss an engineer don't it?
https://images.2carpros.com/forum/automotive_pictures/30961_anger1_1.jpg
Feb 10, 2007 at 11:41 AM
PIERSALLG
Thanx. I'll worm under there and look.
Feb 10, 2007 at 11:51 PM
PIERSALLG
Oops. More data. Now it seems that neither the cruise control nor backup lights work along with turn signals. So perhaps the flasher isn't the offender. Anything obviously in common with those three things?
Feb 11, 2007 at 12:23 AM
SERVICE WRITER
  • 9,123 POSTS
Check fuse #27 in the central junction block on the left lower side of the dash.
https://images.2carpros.com/forum/automotive_pictures/30961_cjb_1.jpg
Feb 11, 2007 at 4:05 AM
Suggested Repair
Check fuse #27 in the central junction block on the lower left side of the dash. The turn-signal flasher is in auxiliary relay box #1 behind the glove box, but shared loss of cruise control and backup lights points first to that fuse.
Conversation Summary
A 2003 Ford Excursion has inoperative turn signals while the hazard flashers, bulbs, and an initially checked fuse are good. The flasher was located in auxiliary relay box #1 behind the glove box. After cruise control and backup lights also failed, the expert advised checking fuse #27 in the central junction block on the lower left dash.
