1995 Ford Escort Outer Tie Rod Fix
VTCAROL50
  • 22 POSTS
I need a left outer tie rod. How easy is this to repair myself? What should it cost to have it repaired at a shop and what kind of shop would be best suited to do this?
Mar 17, 2007 at 2:16 AM
TAURUSWHEEL
  • 718 POSTS
Outers aren't that hard to replace, you'll probably need some sort of pickle fork to bust it apart, most parts stores rent for a nominal fee or free with cc... not sure of labor costs, an outer tierod probably costs between 15-45 dollars depending on what brand.. any locally-owned reliable auto repair place can do it,, stay away from the lifetime guarantee deal some offer, you'll pay way too much
Mar 17, 2007 at 10:25 AM
Suggested Repair
An outer tie rod is a moderate DIY job if you have a pickle fork, which many parts stores rent. The part typically costs about $15–45. A locally owned independent shop can replace it; avoid lifetime-guarantee packages that cost more than necessary.
Conversation Summary
The owner of a 1995 Ford Escort asked how hard it is to replace a left outer tie rod, what shop labor might cost, and which shop type is best. The expert said outer tie rods are not especially hard to replace and usually require a pickle fork, often available to rent from a parts store. The part was estimated at $15–45 depending on brand, labor cost was unknown, and a reliable locally owned shop was recommended over lifetime-guarantee deals.
