1995 Ford Escort Steering Wheel Vibration
THEC0WBOY
Hello Everyone,
My ford escort has 200 000 km, and has a 1.8L engine. About 2 weeks ago the steering wheel started to vibrate. At first, you could only notice it when you were doing around 50km/hour. It has gotten far worse in the past few days. If I'm trying to drive in a straight line, the steering wheel won't stop vibrating. If I steer slightly to the left or right the vibration almost entirely goes away. Any clue what this might be?
I'm a car noob, but I've decideded to attempt to fix this problem myself. I was planning on replacing both outer Tie Rods tonight, then having the wheels alligned. Any chance this might be the problem? And, if it is... any tips on changing the tie rods?
Thanks in Advance!
Car Noob
Apr 17, 2007 at 6:31 AM
MERLIN2021
  • 17,250 POSTS
Hey noob go to an alignment shop and let them tell you whats wrong...they do free estimates...
Apr 17, 2007 at 8:37 AM
BESTBET777
  • 89 POSTS
You may have tthrown a wheel weight or your font end may be ready tto come apart. Don't fool around, gett it into a front end shop now.
Apr 17, 2007 at 8:15 PM
Suggested Repair
Have a front-end or alignment shop inspect the car before replacing parts. A thrown wheel weight or worn front-end components may be causing the vibration.
Conversation Summary
A 1995 Ford Escort with a 1.8L engine and about 200,000 km developed steering-wheel vibration that started near 50 km/h and worsened, especially when driving straight; slight steering input reduced it. The owner planned to replace both outer tie rods and get an alignment. Experts advised a free estimate at an alignment or front-end shop rather than guessing, noting a possible thrown wheel weight or failing front end.
