1995 Ford Escort Computer Reset
ASNO
I'm having problems with my car first of all how do you reset your computer I have a 1995 ford escort 1.9L and do you need to restart after you put a new throttle position sensor in and also I installed the new one it worked but shortly after it died and wont even start is this because I didn't reset my computer...please help......main question how do you reset them
Thanks
Feb 1, 2006 at 6:47 PM
MVANNESSJR
  • 223 POSTS
Disconnect the battery for 5-10 minutes, the positive, not the ground. Should do the trick.
Feb 1, 2006 at 11:23 PM
Suggested Repair
Disconnect the positive battery cable for 5-10 minutes to reset the computer.
Conversation Summary
The owner of a 1995 Ford Escort 1.9L asked how to reset the computer after installing a new throttle position sensor. The car ran briefly and then would not start, and the owner wondered whether a computer reset was needed. The expert advised disconnecting the positive battery terminal, not the ground, for 5-10 minutes.
