1995 Ford Escort No Start
TABNEYS
95 escort ,,fuel pump is good,,gets fuel to the rails,,has spark,,will start with starting fluid,,will not run on its own after that,,will not start on its own,,any suggestions ?
Aug 28, 2007 at 12:34 PM
MERLIN2021
  • 17,250 POSTS
If it runs with starting fluid, (don't overdo it!) It's a fuel delivery issue! Either the pump is defective, or the pressure regulator is. Get a pressure test!
Sep 1, 2007 at 2:29 AM
Suggested Repair
Perform a fuel pressure test. Because the engine runs briefly on starting fluid but will not stay running, suspect a fuel delivery problem such as a defective fuel pump or pressure regulator.
Conversation Summary
A 1995 Ford Escort will not start or stay running on its own, although it has spark, fuel reaches the rails, and it will start briefly with starting fluid. The owner believes the fuel pump is good. The expert says starting on fluid points to a fuel delivery issue and recommends a fuel pressure test to check the pump and pressure regulator.
