outer left tie rod
FORD ESCORT
MIKE EVANS
how to install outer left tie rod for a 2003 ford escort zx2 with 47,000 miles
Nov 10, 2007 at 5:42 AM
MERLIN2021
  • 17,250 POSTS
Remove front tire, remove cotter pin if it has one, remove the nut, back off the lock nut just so it breaks free, use a tie rod fork or seperator and pop the tie rod out of the knuckle, unscrew the end and count the turns, screw on the new one the same number of turns it took for the old one to come off, put it in the knuckle and tighten. lock the lock nut down, grease it, put tire on!
Nov 10, 2007 at 6:18 AM
