1996 Ford Escort Brake Caliper Binding
RAPIDSPEC
my front brake caliper keeps binding on my disc. i have replaced the old bendix caliper with a new one but i,m still having the same problem. it is a ford escort si 1.8 petrol non abs 1996
Jul 21, 2007 at 10:53 AM
CHEVY22
  • 1,375 POSTS
DID YOU BLEED THE CALIPER OUT WHEN REPLACING ?? IF SO REMOVE THAT WHEEL AND GRAB AN EXTRA FOOT SEE IF YOU HAVE SUFFICIANT FLOW FROM THE BLEEDER , YOU MAY HAVE A COLLAPSED LINE AND GO OVER YOUR PREVIOUS REPAIR JUST TO MAKE SURE ITS RIGHT
JIM
Jul 22, 2007 at 12:55 AM
Suggested Repair
Confirm the new caliper was bled, then check fluid flow at the bleeder with the wheel removed. Inspect for a collapsed brake hose and recheck the previous caliper installation.
Conversation Summary
The owner of a 1996 Ford Escort SI says a front brake caliper keeps binding on the disc even after the old Bendix caliper was replaced. The expert asks whether the caliper was bled and recommends checking flow from the bleeder, looking for a collapsed brake line, and reviewing the previous repair.
