1986 Ford Escort Heater Core Removal
JERRYC41
How do I remove the heater core on a 1986 Ford Escort with AC? It has the core with one pipe over the other.
I have spent quite a bit of time under the dash, but I cannot figure it out. The hoses are already disconnected from the core.
Dec 8, 2006 at 1:59 AM
2CARPRO JACK
  • 11,533 POSTS
Some Fords you have to remove the dash and the entire plenum box.That includes evacuating the A/C.If there isnt an access hatch on the bottom of the plenum box then that might be where you are heading
Dec 8, 2006 at 3:53 AM
Suggested Repair
Check the bottom of the plenum box for an access hatch. If none is present, plan to remove the dash and the entire plenum box, which includes evacuating the A/C system.
Conversation Summary
The owner of a 1986 Ford Escort with A/C has already disconnected the heater hoses but cannot determine how to remove the stacked-pipe heater core from under the dash. The expert says some Fords require dash and full plenum-box removal, including A/C evacuation, if there is no access hatch on the bottom of the plenum.
