1994 Ford Escort Little Heat
LAPHAMK
1994 Ford ESCORT 1.9 LITRE. 101,000 miles. I have very little heat and even then it's only for a few moments. The temperature gauge acts as if I do not have a thermostat as it goes up and down as I drive, but the thermostat is brand new and can only go in one way (idiot proof). I flushed my heater core and it seems to be fine and it does not leak. The door flap that opens and closes when I change from defrost to heat, etc is working properly and moves the way it should. The blower motor and fan turns fine as well. Why am I still not getting any heat? Help! Oh, my car is not equipped with any heater control valve either. :roll:
Sep 21, 2006 at 3:06 AM
NOS
  • 320 POSTS
it is very possible that your water pump is not forcing enough water through the system. and it is not uncomon to get a bad thermostat so i wouldn't rule it out. (the point side out towards the radiator).(NOS) 8) also check your belt routeing and make sure it is right if it has been changed and not instald corectly, it could be turning the pump the wrong way :roll:
Sep 21, 2006 at 11:37 AM
HEAVYDUTY
  • 60 POSTS
bad head gasket
Sep 24, 2006 at 12:52 PM
NOS
  • 320 POSTS
also make sure that the knob inside is not broken on the back you might be turning it but it may not be turning for the heat. pull it off and take a pair of needle nose pliers and see if it turns any more or just make sure the knob is not broke. (NOS) 8)
Sep 25, 2006 at 12:35 PM
BUBBA_KOSKI
  • 129 POSTS
fuse jump the fan, check the relay and fuses, if you got a new radiator fan motor make sure its for A/C, check for shorts or misguided wiring problems.
Sep 28, 2006 at 3:38 PM
DEMEARSJR
  • 110 POSTS
NOS seems to have the right idea on this one.
Sounds like a bad water pump.
Oct 1, 2006 at 4:36 PM
Suggested Repair
Check water-pump circulation and belt routing so the pump turns the correct way, and recheck the thermostat even if it is new. Also confirm the heater control knob actually moves the blend door.
Conversation Summary
A 1994 Ford Escort with 101,000 miles has little heat and a temperature gauge that rises and falls while driving. The owner reports a new thermostat, a flushed heater core with no leak, a working blend door and blower, and no heater control valve. Experts mainly suspect weak water-pump circulation, a defective thermostat, or incorrect belt routing, and also suggest checking that the heater knob is not broken. A head-gasket comment and cooling-fan fuse advice were less directly supported.
