1993 Ford Escort Oil in Radiator
TRIUMPH406
Hi all,
my wifes '93 escort blew the hose of the bottom radiator connection. I put it back on, when I looked at the radiator cap, it looks like it's got a layer of oil on the cap, plus there's oil residue inside the radiator.
When we start the car, even when warm it blows water out of the exhaust.
Is the cylinder head likely to be cracked, or just a bad head gasket?
How long does it take to change a head gasket?
Thanks for any help
Regard Dave
Feb 18, 2006 at 2:40 PM
GODBEAR839
  • 77 POSTS
sorry to bring bad news but those year escorts were known for having bad heads.it's probably cracked and you will need a new/rebuilt one.
Feb 20, 2006 at 2:38 AM
Suggested Repair
Replace the cylinder head with a new or rebuilt unit. These 1993 Ford Escorts were known for cracked heads, and oil in the radiator plus water from the exhaust indicate the head is probably cracked.
Conversation Summary
The owner of a 1993 Ford Escort reported a lower radiator hose blowing off, oil on the radiator cap and inside the radiator, and water blowing from the exhaust even when warm. They asked whether the cylinder head was cracked or the head gasket had failed, and how long a gasket replacement takes. The expert said these Escorts were known for bad heads, that the head is probably cracked, and that a new or rebuilt head is needed.
